Custom Residential Architects Network
Expand all | Collapse all
Code Wall Assemblies - Alternate to Code described R20+R5continuous insulation.
  • 1.  Code Wall Assemblies - Alternate to Code described R20+R5continuous insulation.
    Posted 03-22-2024 04:54 PM
    In NJ we have adopted the 2021 version of the IBC and IRC at the beginning of 2023, and along with the new code came requirements for higher insulation values. Previously under the 2018 version code could be satisfied by a 2x6 wall with R20, or a 2x4 wall with R13 and R5 continuous insulation. Now under the 2021 version the whole State must provide R20 + R5 continuous, or R13 + R10 continuous, or a single cavity wall of R30. I've found that during the past year that every builder I discussed this with was unaware of the change - and some I caught in mid-bid where they had gravely mis-estimated the work they would need to supply. Furthermore over half the architects I spoke to about this were also unaware of the change.
    I became very concerned because the overwhelming implication is that the continuous insulation layer must be at the exterior, and I was witnessing an entire State of builders being thrown into detailing flashing and water tightness with an exterior layer of insulation which they had zero experience with. There are alternates to this, and in fact the 2021 code introduced a table of minimum U-Factor values which bypasses the familiar table of insulation values. Another run-around is the Res-Check software package where the option to measure the total performance can prove compliance with alternate assemblies. However builders certainly, and admittedly most architects are not in the routine of calculating U-Values of their wall assemblies, and in fact Res-Check is quite limited in the format of data entry for insulation - its cavity or continuous only.
    Some may argue that the code does not require the continuous layer to be exterior, but that does not hold up. The rush of material manufacturers to bring to market products that are specifically aimed at R5 continuous exterior insulation is palpable. Sheathings with insulation laminated, rigid insulation with air water barrier pre-laminated, dense and rigid batts are all being touted as the solution. These companies have invested millions in developing and promoting products to answer what is obviously a call to exterior insuation in the building code.
    So I along with a couple of colleagues from New England who have already been working under the R20+5continuous requirement for many years have written a White Paper to document compliance of a greatly simplified compliant wall assembly consisting of R20+R6 furred continuous insulation located at the interior. This requires much less work than continuous exterior insulation, and more importantly requires no new skills or techniques for successfully flashing and making the exterior side weather tight. And the performance is marginally better than R5 continuous.
    It is our intention to share this widely, so that architects and builders are not caught unprepared for the new code requirements when and if they come to your location the way the have just landed on New Jersey. The white paper can be downloaded from this link:
    White Paper 20+6fci wall 14Nov2.pdf
    Dropbox remove preview
    Shared with Dropbox
    View this on Dropbox >
    Please share with your colleagues and builders.
    Gregory La Vardera
    Gregory La Vardera Architect
    Merchantville NJ
  • 2.  RE: Code Wall Assemblies - Alternate to Code described R20+R5continuous insulation.
    Posted 03-25-2024 05:43 PM
    I see a WUFI model was created, but do not see a hygrothermal analysis. Could you please point us to that data or share, if not included in the white paper?  The location of the vapor barrier may prove problematic in some (micro)climate zones.
    Jonathan Huffmaster AIA
    Architectural Design Group, pllc
    Ham Lake MN
  • 3.  RE: Code Wall Assemblies - Alternate to Code described R20+R5continuous insulation.
    Posted 03-25-2024 11:01 PM
    Hi Jonathan, thanks for looking.
    In short no hygrothermal analysis is included in the White Paper because the Code tables that relate insulation requirements does not address this.
    That said the assemblies described in the Code, and the alternates we describe are not universal - no assembly is. People building in "micro" climate zones will always have to be mindful of the assemblies vapor performance. I will say that the assembles we describe with continuous insulation at the interior side are much more resilient than Code described walls with vapor retarding exterior insulation.
    Greg
    Gregory La Vardera
    Merchantville NJ
  • 4.  RE: Code Wall Assemblies - Alternate to Code described R20+R5continuous insulation.
    Posted 03-26-2024 12:53 PM
    Edited by Paul M. Reynolds AIA 03-26-2024 12:53 PM
    My understanding is that's the entire point of the exterior insulation... not for insulation's sake but to keep the sheathing warm(er) and reduce the risk of condensation. Pushing the dew point...
    I need to dig into the white paper, yet... It's also possible that I'm missing something.
    Paul Reynolds AIA
    HAUS | Architecture For Modern Lifestyles
    Indianapolis IN
  • 5.  RE: Code Wall Assemblies - Alternate to Code described R20+R5continuous insulation.
    Posted 03-26-2024 01:14 PM
    Paul,
    Exterior insulation can certainly warm the inside surface of the sheathing, and this can prevent condensation – if you are going to let interior conditioned air un-fettered access to your stud cavity. However, if you are controlling vapor at the inside of your wall assembly then in theory it should not be reaching the sheathing in any great volume to cause condensation. The caveat here is that kraft faced insulation is far from continuous, and electrical device boxes make regular holes in it.
    When you use an exterior insulation that is not vapor open - such as a foam insulation layer - then you are adding a vapor retarder to the exterior (on top of your sheathing which is already a vapor retarder). So when you are going to do this, best practice is not to also put a vapor retarder at the interior - because it should be easy for the wall to dry-out in at least one direction.
    When you use an exterior insulation that is vapor open - like mineral wool - this concern goes away, and you can control vapor at the interior side, which is more ideal and more resilient for heating climates in the Zones in question here.
    Why is that? Because controlling vapor's entry into the stud cavity is always more effective placed at the interior side. If the wall experiences "out of range" conditions it will still perform perfectly. By "out of range" conditions I mean like when an Arctic air mass sinks into the central US, and temperatures drop to the teens in Texas. While this is going on, Northern central States are experience -30F. Not just overnight either - we seen it recent winters for a week or more. Under these conditions the vapor closed exterior insulation wall may experience back of sheathing temperatures below the interior dew point for extended periods. Will it make your house fall down? No. Will it cause mold? Maybe. But in general, its clear that this is not a smart approach in many locations.
    This whole discussion about the merits of where you control vapor in a wall assembly is way beyond the purpose of this White Paper, which is just to document that the interior continuous insulation wall is compliant with Code. The benefit is that these walls are easier and faster to build, and cost less in time and money.
    Gregory La Vardera
    Merchantville NJ
  • 6.  RE: Code Wall Assemblies - Alternate to Code described R20+R5continuous insulation.
    Posted 03-27-2024 06:43 PM
    And in very northern climates, things don't dry out. So best to keep the moisture on the warm side of an interior vapor retarder as much as possible.
    Mike Mense FAIA
    Architect, Writer, Planner, Painter
    mmenseArchitect
    mensenyc on Instagram
    Hamilton Heights, NYC and Snohomish WA
  • 7.  RE: Code Wall Assemblies - Alternate to Code described R20+R5continuous insulation.
    Posted 03-26-2024 09:43 AM
    Thanks for sharing this Greg. What a great resource!
    I worked on a recent addition, specifying 1 7/16" THICK ZIP SYSTEM R-6 INSULATED WALL SHEATHING AND FLASHING TAPE SYSTEM, and utilizing ResCheck for energy compliance submission.
    Have not dove into the details of the White Paper to see if any of the solutions utilize insulated Zip Systems, but thought I's offer it as an option.
    Really appreciate the resource for future projects!
    Thank you,
    Brooke
    D. Brooke Robinson
    16 Idlebrook Lane
    Aberdeen, NJ 07747
    p: 732.441.3532
    e: brooke@draworkshop.com
    w: www.draworkshop.com
  • 8.  RE: Code Wall Assemblies - Alternate to Code described R20+R5continuous insulation.
    Posted 03-26-2024 10:54 AM
    Please dig into the White Paper. The alternate is a furred continuous insulation layer at the interior side, which does not rely on the expense of Zip's insulated sheathing, or the complexity of exterior side detailing that comes with other forms of exterior insulation. It offers slightly better performance than the continuous exterior R5, and much easier to build. This emerged out the situation in my state of NJ where builders, and architects, have really been caught with their pant's down - inexperienced at detailing and building exterior insulation, with the grace period for the 2018 code recently expired.
    In my own practice I have a embargo on Zip sheathing. I need 50yrs before I believe that tape is a suitable replacement for lapped flashing details. Note - I will be dead by then, so this is one choice I can simply take off the table.
    Gregory La Vardera
    Merchantville NJ
  • 9.  RE: Code Wall Assemblies - Alternate to Code described R20+R5continuous insulation.
    Posted 03-27-2024 05:39 PM
    Since we are all visual orientated, and I hate to type, I thought I would share a few videos that have some good information regarding continuous insulation.  My gig is multi-family, and we have been dealing with ci for some time, especially in the colder climates.  When you have several thousand windows in one project, you learn quickly how to detail ci correctly and cost effectively. It is the future, so embrace it and deliver a better building to your client.
    https://buildingscience.com/video/perfect-wall-finally
    https://www.youtube.com/watch?v=5-Fy5a9WPV4
    https://www.youtube.com/watch?v=sV7yC4XGeTE
    https://www.youtube.com/watch?v=W5zR3GeUjG4
    https://www.youtube.com/watch?v=ZkgJ7BzrQp8
    HLR Logo
    Tom Taylor, AIA
    Hensley Lamkin Rachel, Inc.
    14881 Quorum Dr, Ste 500, Dallas, TX  75254
    O: 972.726.9400 x131 | C: 469.766.8784 | W: www.hlrinc.net
    Member International Institute of Building Enclosure Consultants
    2027 International Residential Code Building Code Committee
    2024 IECC Residential Envelope and Embodied Energy Committee
  • 10.  RE: Code Wall Assemblies - Alternate to Code described R20+R5continuous insulation.
    Posted 03-28-2024 04:18 PM
    Respectfully Tom - glad you have had good experiences with exterior CI, but the situation we in NJ, and other states in Zones 4&5 that move from 2018 to 2021 codes find themselves in is an entire local industry, builders And architects, with little to no experience in exterior CI, which is clearly a recipe for state wide building errors that will emerge sometime in the future.
    The fact is the interior side work is easier, faster, and less costly in time and money. Thats a great advantage you could deliver to your clients.
    I have no prejudice against exterior side CI, and in fact I believe it can be an effective part of a multi layer wall. I would favor a wall with R5 exterior and R6 interior over a wall with R10 on either side. Two thermal breaks outperform a single thermal break for the same amount of insulation. But I don't encounter code requirements for that level of performance in my region. Unless you are pursuing a performance standard certification greater than code it would not make sense.
    As far as the video links. I've watched them all in the past, and frankly I find the "Perfect" Wall imperfect. If it was perfect it would be more affordable than other options and we would see it being used widely. While its author is qualified, I don't find the cult of personality around him helpful, and actually quite embarrassing for our profession at times. If he inspires you to better work, then good for you.
    best, Greg
    Gregory La Vardera
    Merchantville NJ
  • 11.  RE: Code Wall Assemblies - Alternate to Code described R20+R5continuous insulation.
    Posted 05-15-2024 10:38 PM
      |   view attached
    I just wanted to update this thread with additional information that I came across quite accidentally. I was presented with an ad for a website:
    continuousinsulation.org
    This site has extensive and deep information on how to properly implement continuous exterior insulation in construction, although it appears primarily focused on foam insulation products. The information is good, and accurate - a good guide if you intend to specify the products featured in its information. There is even an freestanding PDF document which is a Continuous Insulation RESOURCE GUIDE. All of this information is gathered, and formatted, and presented free of charge.
    A closer look reveals this site is authored by Applied Building Technology Group - a large building science consultancy. I have no proof, but I suspect this whole endeavor is a paid effort on the part of Applied Building Technology Group, presented and posing as a dot-org, when in all likelihood this is a coordinated ad campaign posing as public advocacy. Large Building Science consultants often offer reports on findings funded by their clients as free public advice, coincidently recommending their clients products, because after all that is what was the subject of the paid study. This is quite common. It is up to us to be aware of these practices, and separate the advertising from the advice.
    None of this is meant to condemn or accuse ABTG of any wrong doing, but rather to demonstrate the immensity of the industry pressure on the adoption of continuous exterior insulation, and the strong held belief of industry that this is in fact what the code is calling for. Remember - it is not, and the interior side continuous insulation method detailed in the White Paper is faster, easier, and less expensive in money and time. Think twice before you burn your client's budget on exterior side continuous insulation.
    Gregory La Vardera
    Merchantville NJ
    Attachment(s)
  • 12.  RE: Code Wall Assemblies - Alternate to Code described R20+R5continuous insulation.
    Posted 05-16-2024 01:44 PM
    You are absolutely correct Gregory, the site acknowledges that it is funded by the American Chemistry Council's Foam Sheathing Committee. Members include BASF, Carlisle, DuPont, Owens Corning and others.
    You are also correct that continuous insulation applied to the interior is cheaper and easier.  But after building several projects with exterior c.i, I believe the benefits far out weigh the small amount of money and extra effort.
    Tom
    HLR Logo
    Tom Taylor, AIA
    6201 W Plano Parkway   Suite 100   Plano, Texas 75093
    Safety Assessment Program Evaluator
  • 13.  RE: Code Wall Assemblies - Alternate to Code described R20+R5continuous insulation.
    Posted 05-16-2024 01:50 PM
    The same performance benefits accrue when doing continuous at the interior. I think you are also trivializing the cost and effort by describing it as "small".
    Gregory La Vardera
    Merchantville NJ
