Community HTML
Glass
Quick Links
Who we are
The AIA Technology in Architectural Practice Knowledge Community (TAP) serves as a resource for AIA members, the profession, and the public in the deployment of computer technology in the practice of architecture. TAP leaders monitor the development of computer technology and its impact on architecture practice and the entire building life cycle, including design, construction, facility management, and retirement or reuse.
The call for volunteer terms starting in January 2024 is now open! Learn more about joining the TAP leadership group, or learn about other volunteer opportunities across the organization.
Join us in San Francisco on June 7 for the TAP Symposium at A'23, a continuation of our TAP BCC series!
  • 1.  Syncing Problem between Autocad and MS SharePoint
    Posted 03-30-2023 02:17 PM
    My nine-person firm recently converted from an in-firm server to cloud-based storage via MS Sharepoint/One Drive.   Autocad creates two temporary hidden file extensions when a drawing is in use: .dwl & .dwl2. These files are not lock files. SharePoint will not recognize these file extensions, preventing a snyc.  Microsoft allows blocking of certain file types, but a recent post describes a negative result from blocking within SharePoint is numerous non-sync warnings.    We would like to sync files when we collaborate within our office without having to close out of the file. Does anyone have experience with issue? Any way to turn off the One Drive non-sync warnings?
    Thanks.
    Gregory Wiedemann, FAIA
    Wiedemann Architects LLC
    Bethesda MD
    Join us at A'23 for technology sessions! June 7-10, San Francisco. Click here to learn more.
  • 2.  RE: Syncing Problem between Autocad and MS SharePoint
    Posted 03-31-2023 08:22 PM
    Maybe it would help to reach out to your Microsoft rep for access to the new Autodesk integration?
  • 3.  RE: Syncing Problem between Autocad and MS SharePoint
    Posted 04-01-2023 08:06 PM
    According to Autodesk, AutoCAD only works with SharePoint/OneDrive if the folder/files are sync'ed locally. https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Microsoft-OneDrive-and-SharePoint-for-AutoCAD-products.html
    I occasionally work in AutoCAD files stored in OneDrive and sync'ed locally without issue.
    Since the dwl files are not lock files, it may be possible to prevent their creation via a registry edit mentioned here: https://forums.autodesk.com/t5/autocad-forum/disable-creation-of-dwl-dwl2-files/td-p/5803374
    Daniel Stine AIA
    Lake Flato Architects
    San Antonio TX
