More often than not when we apply a note "For Reference Only", the documents are for scopes to be performed by others. Either an adjacent project or work performed by an owner or owner's vendor. Usually the project will have points of coordination or overlap that will be coordinated by both parties meaning the projects contractor and other contractor/vendor.
A better example would be an enabling project for a larger program running underground utilities across a campus, the drawings for the enabling project would be provided as "For Reference Only" for bidding contractors to fully understand their points of connection and any potential underground coordination points with work not performed under their contract.
Miguel Antonio Martín,
RA, AIA, RID, A.ASHRAE, NCARB, ICC, NFPA, NBAA
Vice President – Chief Operations Officer
Principal
Licensed Architect: AL-8727 | FL-AR98279 | GA-RA15048 | NC-15254 | NY-41748 | OH-2118586 | PA-RA407958 | SC-11315 | TN-107841 | TX-29296 | VA-19314
Licensed Interior Designer: FL-ID6975
Qualifying Professional: AL | GA | NC | OH | TN | TX
MLM-Martin Architects, Inc.
668 N. Orlando Ave. Suite 107
Maitland, FL 32751
o 407-897-6764 | c 407-617-0715 | d 407-551-1409
Mamartin@mlm-martin.com
MLM-Martin Architects, Inc. is a certified Minority owned small business and recognized by the unified certification process of the Department of Transportation as a Disadvantaged Business Enterprise (DBE)
MLM-Martin Architects, Inc. is a registered Architectural Practice AL#CA 1329 | FL#AA-C002208 | GA | NC#54077 | OH#21314457 | TN #5600 | TX #BR 4299
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
