Making Homes Energy-Efficient – Tips To Consider
By Bob Gorman posted 05-26-2017 11:08
Your home is a system at its basis. It is always possible to improve performance and save money if you know how to reduce building loads. Installing appliances and systems that are of an appropriate size is necessary. Generally speaking, oversizing will increase costs and worsen performance.
The really good news is that you do not need to invest a lot of money into making huge changes. AccuServ, leading AC service providers, highlight many different small changes that make huge differences on the long run. The truth is that making a home really energy-efficient is something that will be highly beneficial in the long run. This is what you are interested in at the end of the day. The suggestions below will help you to achieve just that.
Checking The Entire Home For Proper Insulation
Energy efficiency starts with the insulation that is added to the home. If insulation is effective the heat will flow through the home at a slower rate. Less energy is going to be necessary to both cool and heat a house. When there is no wall insulation present, huge problems can appear and energy consumption will be pretty high. Be sure that you check the entire home and that you are sure proper installation is present. When you do this you can be sure that the best system is created. Do be sure that you check the attic and the basement since these two are often overlooked.
Replace Or Upgrade Windows
When you have leaky or old windows, it is time to replace them with the models that are more energy efficient. Alternatively, some of the windows can be upgraded through weatherstripping. Replacing windows with the main purpose of saving energy is usually not cost-effective unless older models are replaced with newer models. Even then the savings are low. However, in the event you do need to replace the windows anyway, why not install some models that are completely energy efficient.
Taking Advantage Of Foliage
When the home is old and insulation is poor, you can always go for proper landscaping. That can save you energy when foliage appears on the west side of a house. During summer foliage is going to block the appearance of extra infrared radiation and in the winter you will be able to have radiation come through because branches will be bare. This is an option to consider when the home does not have perfect insulation since when the insulation is proper, foliage does not bring in high energy increases.
Replacing The Old Furnace
When your home has a furnace that was built before the year 1992, there is a huge possibility that around 35% of used fuel is lost. Service life is also most likely almost over. You would have to replace with a newer model that has an annual efficiency rating of a minimum of 90%. This will bring in really low wastes and the heating bill will be lower by around 27%. The investment may be high but the savings are higher.
#Articles #BestPractices
